Use prerequisites to save time
In most devices, you'll want to remove the battery early in the repair process. Instead of having to repeatedly explain how to remove the battery at the beginning of every guide, you can write the battery replacement guide once, and then select the battery guide as a prerequisite in future guides. After adding the prerequisite, your battery replacement steps will show up automatically at the beginning of your new guide, and you can add further steps from there.
The battery is just one example; any number of guides can be used as prerequisites.
Effective use of prerequisites can be a huge time saver, but there are potential pitfalls. You can only use prerequisites for portions of the disassembly that are sequential. For example, suppose we’re writing guides for the iPhone 16 Pro. After investigating the design of the device, we've concluded that the components can be removed in the following order:
1. Back Glass
2. Taptic Engine
3. Loudspeaker
3. Microphone
Notice that the loudspeaker and microphone share the same number. This means that once you've removed the first two components, you can choose to remove any of the next two. The loudspeaker guide is not a prerequisite for the microphone, because you don’t have to remove the loudspeaker to take out the microphone.
This can get tricky to keep track of in your head, so draw a tree diagram that shows the order components are removed from your device. This will be helpful (and save tons of time) later:
You can see that before you even get to the microphone, for example, you must go through the same steps that are found in the Taptic Engine guide. The Taptic Engine and back glass guides are both prerequisites for the iPhone 16 Pro Microphone guide.
We’ll go over how to import a prerequisite guide later on the Add Guide Details page.
