IN THIS MILESTONE, YOU WILL CREATE GUIDES SHOWING HOW TO REPLACE THE PROPOSED COMPONENTS OF YOUR DEVICE.
Checklist:
You are finished with your guide images when they:
Are well-lit and correctly exposed
Are shot in landscape orientation
Show a person's hands performing the actions being described without obstructing the view
Place the action in the center of the frame
Are zoomed in far enough to see relevant detail while still showing enough of the device to provide reference points
Are in focus—not blurry or grainy
Have correct white balance without a colored tint
Have a clean, white background free of distracting clutter
You are finished with your guide text when it:
Is easy to understand and follow for an audience with an average to below-average technical background
Is clear and concise—free of verbose and muddled directions
Avoids vague language
Describes the procedure with adequate detail
Correctly identifies the device components and tools being used
Is free of major errors in grammar, punctuation, and spelling
Includes the head types (e.g. Phillips #0) and screw lengths (in mm) of every screw
Follows the standard format for titles ([Device Component] Replacement) for the guides
You are finished with your guide mechanics when they:
Correctly use prerequisite guides to create an easy-to-follow "chain" of replacement guides
Include a descriptive introduction outlining why the procedure is necessary, background on the procedure, and other relevant information
Include all parts of the Details section, such as the difficulty, time required, and tools
Properly include colored markup in guide photos with appropriate bullets colored to match them
Make proper use of the Note, Reminder, and Caution bullets
EMAIL US WHEN…
...your first guide is complete. We'll be happy to review your guide, answer questions, and provide feedback to help with the rest of your guides.
Overview
In this milestone, you will create guides showing the replacement of each component you chose in your proposal. (Remember, you are not responsible for creating a teardown or for repairing broken components.) Since reassembly is usually just the reverse of disassembly, you should not write reassembly steps. The final step in each guide will show the removal of the component being replaced. By default, each guide automatically concludes: “To reassemble your device, follow these steps in reverse order.”
Each completed guide should contain the following:
A title
A descriptive introduction
Estimated difficulty and time required
A list of any required tools
Step-by-step instructions written in clear, complete sentences
An accompanying photo or photos to demonstrate each step
Visual markup, when appropriate, highlighting key areas of the photos, matched to color-coded bullets in the text (see guidelines here)
Keep in mind that your final guides will have a global audience, so you shouldn’t rely on the text alone to communicate key information. Ideally, your readers should be able to complete the guide using only the photos, or only the text. Both the written and visual portions of your guides should work together, yet be able to stand on their own.
Example Pages
The following examples from past projects give a good idea of what your completed guides should look like.
To see more awesome student work, check out our Featured Student Guides page.
